pablohoney
Jul 02, 2021Luminary
RBR/RBS 50 firmware 2.7.3.22
New firmware is incoming this week I have been told. No release notes details yet but may fix either device list issues or link rate issue. Keep an eye on https://www.netgear.com/support/product/RBK50...
RASB
Jul 06, 2021Initiate
The current posting on the web site is incorrect. The zip file for the router RBR50 is fine the file for the RBS50 satellite contains the RBR50 image file as well. The RBS50 image is missing.
I spoke with support and was disconnected during the call and no one has called back so ....
So I am currently half updated. (anyone aware of any pit falls running hybrid on firmware revs until update is posted correctly.
- pablohoneyJul 06, 2021LuminaryI have just noticed that too! I have emailed my contact directly in support to make them aware of the issue and asked them to fix it ASAP.
- tagteamJul 06, 2021Virtuoso
In case anyone else reading this thread is interested:
Bug Fixes:
- Fixes the DNS query failure issue that occurs when traffic meter and daylight saving are enabled
Security Fixes:
- This firmware addresses security vulnerabilities.
- pablohoneyJul 07, 2021LuminarySo after installing this latest firmware, the link rate issue appears to be fixed in that you can now see the link rate of your devices that are connected to your satellites. However, the missing devices issue is still present.
- pdeethardtJul 10, 2021Apprentice
pablohoney wrote:
So after installing this latest firmware, the link rate issue appears to be fixed in that you can now see the link rate of your devices that are connected to your satellites. However, the missing devices issue is still present.That's disappointing about the missing devices issue. One of my Ring cameras always shows disconnected, even though it's connected and functioning just fine. Hopefully the next update will resolve that.
