pablohoney
Jul 03, 2021Luminary
RBR/RBS 50 firmware 2.7.3.22
New firmware is incoming this week I have been told. No release notes details yet but may fix either device list issues or link rate issue. Keep an eye on https://www.netgear.com/support/product/RBK50...
wimmme
Jul 05, 2021Tutor
spewak And on what version are you running ? I 'm on 2.7.2.104, running pretty stable on RBR50 and RBS50, but not on my RBS50Y ...
polomorales
Jul 27, 2021Aspirant
HELP!, mY RBR50 and 4 RBS50 updated to 2.7.3.22 and now no device will stay on the network. How do I roll back to the previous version 104? It was solid?
- FURRYe38Jul 27, 2021Guru - Experienced User
Try a factory reset and setup from scratch:
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
https://www.youtube.com/watch?v=ePZSc7vnRlQBeen working solid for me:
polomorales wrote:HELP!, mY RBR50 and 4 RBS50 updated to 2.7.3.22 and now no device will stay on the network. How do I roll back to the previous version 104? It was solid?
- MagistusJul 30, 2021Aspirant
Same. I went onto the application on my phone, did the mandatory restart, and now my internet speeds have dropped and my internet drops constantly. What can I do in order to fix this? Or do I have to do a rollback of firmware versions?
- FURRYe38Jul 30, 2021Guru - Experienced User
Magistus wrote:Same. I went onto the application on my phone, did the mandatory restart, and now my internet speeds have dropped and my internet drops constantly. What can I do in order to fix this? Or do I have to do a rollback of firmware versions?
- MagistusAug 04, 2021Aspirant
I have done two (2) complete resets on the ORBI system. Each time after the reset, it updates the firmware and the internet drops to garbage again and/or devices get dropped from the ORBI system. I've started playing around with settings to see if I can make it better; however, I have not been sucessful so far.
Last resort is to manually go back to previous firmware version when we had really good and reliable internet speeds and didn't drop devices.
- nicholbJul 30, 2021Luminary
Go to this page and hit the + by "view previous versions". Download .104 and install manually. You may also need to do a factory reset and manual setup afterward. Just downgrading did not resolve the issue on mine.
