pablohoney
Jul 02, 2021Luminary
RBR/RBS 50 firmware 2.7.3.22
New firmware is incoming this week I have been told. No release notes details yet but may fix either device list issues or link rate issue. Keep an eye on https://www.netgear.com/support/product/RBK50...
Aug 04, 2021Guru - Experienced User
Try to power OFF the RBR and RBS for 1 minute. Pull the power cord as well. Turn back ON. Factory reset the RBR and RBS and setup from scratch. Let us know if this bridges back wired back haul.
Is the RBS directly connected to the back of the RBR or is there a switch in between?
scubabuddy wrote:RBR50 + 2 x RBS 50 firmware just upgraded from 2.7.2.104 to 2.7.3.22
Seems it broke my setup without me clicking to update (I read in another thread that Netgear forced an update - seriously??? WTF??? Is that serious? In the middle of a pandemic, break everyone's wifi while they are working from home?)
Issues found:
* wired backhaul no longer working, only connects using wirelsss (which is poor quality, thus the reason for the wired backhaul). MAJOR ISSUE
* using Android "Netgear Orbi - WiFi System App" version 2.10.6.1635 (the latest, released 23 July 2021) shows both RBS50 as disconnected (red lines), whereas logging into the router itself shows both RBS50 connected using wireless backhaul.
* [subjective] wireless connectivity is poor when via the RBS50 now, previously it was rock solid using v2.7.2.104 with wired backhaul.
* no "enable telnet" option, so no way to properly diagnose or fix
Can I revert to the 2.7.2.104 ? How? Will it "auto-upgrade" itself again? And can I avoid an auto-upgrade by blocking some particular DNS addresses? (Orbi is inside another network).
scubabuddy
Aug 06, 2021Tutor
Doing the full power off for some time (multiple times, I'd already tried it when I posted) eventually got me to something that recognised the Ethernet backhaul. Awaiting feedback on acceptance factor in the household, with 4~5 simultaneous wireless video conferences at any one time during the week with everyone working and schooling from home, it should become evident soon...
- FURRYe38Aug 06, 2021Guru - Experienced User
- scubabuddyAug 06, 2021TutorThere is a switch in between. The only other point of interest is that I have some (up to date) v1 SONOS equipment that I disconnected as well this time, because I had horrible problems with what I think was some spanning tree conflicts about a year ago. SONOS all set to Ethernet only in case you're wondering. Not sure if that was related or not, but with everyone highly reliant on the internet, now is not the time to experiment.
Oh and it is a "dumb switch, unmanaged, and I had also tried power cycling it both the first times when it all failed, and this time that it worked too.- FURRYe38Aug 06, 2021Guru - Experienced User
What is the Mfr and model# of the ethernet switch in the configuration?
Remove the switch from the middle or try a RBS directly connected to the back of the RBR and see if the problem continues.
Yes SONOs have there own wifi and have been problematic with wifi routers. If ethernet is supported on SONOs it's recommended to use ethernet connections for SONOs.
- scubabuddyAug 06, 2021TutorSome other things to add: the Orbi app on my phone now shoes the 2 satellites as connected (wired). Internet achieves ~920/47 2ms on FTTP so I suspect I wouldn't notice any streaming drops because it would catch up pretty quick. Unless the drops lasted for 5-10 seconds or more. When I look at real time internet usage (I have a EdgeRouterX between Orbi WAN and the real world) streaming I see big spikes where the playback device caches at high speeds, then big gaps.
