pablohoney
Jul 02, 2021Luminary
RBR/RBS 50 firmware 2.7.3.22
New firmware is incoming this week I have been told. No release notes details yet but may fix either device list issues or link rate issue. Keep an eye on https://www.netgear.com/support/product/RBK50...
ialexusman
Dec 17, 2021Aspirant
The current posting on the web site is incorrect. The zip file for the router RBR50 is fine the file for the RBS50 satellite contains the RBR50 image file as well. The RBS50 image is missing. I spoke with support and was disconnected during the call and no one has called back so . So I am currently half updated. (anyone aware of any pit falls running hybrid on firmware revs until update is posted correctly.
- CrimpOnDec 17, 2021Guru - Experienced User
Strange. The *.img file inside the *.zip has the correct name for a satellite (RBS50...) Are you saying that the Orbi satellite refuses this file?
