pablohoney
Jul 02, 2021Luminary
RBR/RBS 50 firmware 2.7.3.22
New firmware is incoming this week I have been told. No release notes details yet but may fix either device list issues or link rate issue. Keep an eye on https://www.netgear.com/support/product/RBK50...
mmz06
Aug 13, 2021Guide
scubabuddy wrote:RBR50 + 2 x RBS 50 firmware just upgraded from 2.7.2.104 to 2.7.3.22
* no "enable telnet" option, so no way to properly diagnose or fix
Hi there,
Facing the same issue, I could restore telnet access using the updated version of telnet-enable2.py, enabling back Telnet using V2.7.3.22: https://github.com/bkerler/netgear_telnet
I could push all my existing custom configuration (upnpc, automation, etc.) from here.
Hope this will help you as well...
Work48er
Dec 25, 2021Aspirant
Hi there,
Hi,
The tool sounds promising. However I wonder if you can clarify
- How do you find the MAC address of br0 interface?
- It says the tool is for Netgear Orbi LBR20. Are you using LBR20? If not, did you need to make any changes to get it working with your Orbi router?
Thank you very much .
Joseph
