pablohoney
Jul 02, 2021Luminary
RBR/RBS 50 firmware 2.7.3.22
New firmware is incoming this week I have been told. No release notes details yet but may fix either device list issues or link rate issue. Keep an eye on https://www.netgear.com/support/product/RBK50...
Mar 01, 2022Guru - Experienced User
What do you mean by "intermittent dropping issues"? What is happening?
Top ring LED turn ON? if so, color of LED?
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Try this version of FW?
https://community.netgear.com/t5/Orbi/Missing-Connected-Devices/m-p/2142349/highlight/true#M126110
JusttestFW wrote:
The new firmware has come out and again we are having intermittent dropping issues. I have tried to revert to an older code and set the autoupgrade parameters to 0 but the router still upgrades during the night. This upgrade also takes away the telnet option from the debug menu. I am not happy with having to work on this issue about every other firmware update. Netgear can you help your user community out and get this issue fixed.
JusttestFW
Mar 01, 2022Aspirant
The connectivity drops out and the light on the router goes white and strobes for about 2 min then it picks back up again. I have tried everything in your list multiple times. The ISP is directly connected to the ORBI and receives the IP address from the ISP. I use pingplotter to watch when it drops and to see how long it stays down. I have had several different versions of firmware that have worked just fine and several versions that have the intermittent drop issue. This last update looks like they are trying to cut out our ability to downgrade and turn off auto update.
- FURRYe38Mar 01, 2022Guru - Experienced User
