pablohoney
Jul 02, 2021Luminary
RBR/RBS 50 firmware 2.7.3.22
New firmware is incoming this week I have been told. No release notes details yet but may fix either device list issues or link rate issue. Keep an eye on https://www.netgear.com/support/product/RBK50...
Mar 02, 2022Guru - Experienced User
Did you update FW yet?
Something to try, disconnect the RBR from the ONT. Turn OFF all RBS.
Factory reset and RBR and setup from scratch with the RBR disconnected from the ONT. Walk thru the setup wizard.
Don't enable Armor, Circle or Traffic Meter.
Go in and check the CPU usage with 1 wired PC connected to the RBR. Does the CPU usage track upwards on it's own or maintain a certain level?
What CAT# LAN cable connects the ONT to the RBR? CAT6 is recommended.
JusttestFW wrote:
The ONT device is ADTRAN GPON 452
