pablohoney
Jul 02, 2021Luminary
RBR/RBS 50 firmware 2.7.3.22
New firmware is incoming this week I have been told. No release notes details yet but may fix either device list issues or link rate issue. Keep an eye on https://www.netgear.com/support/product/RBK50...
CrimpOn
Mar 04, 2022Guru - Experienced User
If you are ready to bin the Orbi, what would be the harm in installing V2.7.3.23? Takes maybe 30 minutes. If the Orbi performs no better, what have you lost?
I was given this same version last August, and my Orbi has been fine ever since. To be completely honest, I never seem to experience issues that plague others. This may be because I have never enabled Parental Controls, Armor, or Access Control.
tagteam
Mar 04, 2022Virtuoso
CrimpOn wrote:If you are ready to bin the Orbi, what would be the harm in installing V2.7.3.23? Takes maybe 30 minutes. If the Orbi performs no better, what have you lost?
Yep, ditto. To be perfectly clear, I am not having issues with my Orbi system nor have I EVER had issues with my Orbi system (going on about 5 years now).
I was merely curious as to why Netgear had not updated the firmware in quite some time when they appeared to be doing so quite often over the first 3-4 years after the system was released.
Frankly, I don't care provided they're taking care of any security vulnerabilities that may arise. Other than that, I'm fine with the current firmware since it's not causing any issues on my end (at least none of which I am aware).
- FURRYe38Mar 05, 2022Guru - Experienced User
And doesn't mean that there not working on something. Also Orbi AC, being the more matured product line, may not require as frequent FW updates as new Orbi AX so NG maybe prioritizing FW updates across Orbi product lines.
"If it's working, Don't Fix it!!!." No offence.
- tagteamMar 05, 2022Virtuoso
FURRYe38 wrote:And doesn't mean that there not working on something. Also Orbi AC, being the more matured product line, may not require as frequent FW updates as new Orbi AX so NG maybe prioritizing FW updates across Orbi product lines.
Can't disagree with anything you wrote. As I mentioned, just curious as to whether the company had essentially abandoned the product line completely. I would tend to doubt that, but then it's only logical that they would want users of older products to upgrade to the latest hardware.
