pablohoney
Jul 02, 2021Luminary
RBR/RBS 50 firmware 2.7.3.22
New firmware is incoming this week I have been told. No release notes details yet but may fix either device list issues or link rate issue. Keep an eye on https://www.netgear.com/support/product/RBK50...
Mar 05, 2022Guru - Experienced User
And doesn't mean that there not working on something. Also Orbi AC, being the more matured product line, may not require as frequent FW updates as new Orbi AX so NG maybe prioritizing FW updates across Orbi product lines.
"If it's working, Don't Fix it!!!." No offence.
tagteam
Mar 05, 2022Virtuoso
FURRYe38 wrote:And doesn't mean that there not working on something. Also Orbi AC, being the more matured product line, may not require as frequent FW updates as new Orbi AX so NG maybe prioritizing FW updates across Orbi product lines.
Can't disagree with anything you wrote. As I mentioned, just curious as to whether the company had essentially abandoned the product line completely. I would tend to doubt that, but then it's only logical that they would want users of older products to upgrade to the latest hardware.
