Axel-i's avatar
Axel-i
RBR/RBS 50 LAN issue
I have had an Orbi RBR50/RBS50 mesh network with two satellites for couple years now. Just recently I lost the internet connection for the computer that is connected to the satellite (RBS50) with a LAN cable. With WiFi everything works fine.
All units have SW v2.7.3.22. I have done no changes to the network prior the problem occured for the first time. The connection can be established sometimes, but it succeeds very seldom. I have tried with two different computers and with different LAN cables. Symptoms are the same. I have also switched satellites, but to no avail.
Any good ideas (other than get another mesh system from another supplier)?
I would appreciate a lot if someone could help in this matter.
Axel-i
  • plemans's avatar
    have you tried swapping the satellites to see if it happens to both satellites?
    • Axel-i's avatar
      Axel-i
      Hi Plemans,
      Yes I have swapped the satellites and the result is the same.
      • plemans's avatar
        Meaning the same satellite has issues or the location does?
        did you swap power supplies?
