RobAllen
Jan 06, 2021Aspirant
RBR/RBS10 Mesh wifi
Hello all. I have an Orbi mesh wifi setup. Comprising RBR10 and 2 RBS10 satellites. My question is regarding dhcp. If I disable dhcp on the RBR10 does the mesh system then just act as wifi repeater/s...
- Jan 06, 2021
Correct.
Jan 06, 2021Guru - Experienced User
Yes. There should be a AP mode setting though under Advanced Tab/Advanced Settings for that.
- RobAllenJan 06, 2021Aspirant
So I need to disable router mode and select AP instead so it just emulates the existing wifi correct?
- FURRYe38Jan 06, 2021Guru - Experienced User
Correct.
- CrimpOnJan 06, 2021Guru - Experienced User
RobAllen wrote:So I need to disable router mode and select AP instead so it just emulates the existing wifi correct?
My Orbi has a check box on the Advanced Tab->Setup->LAN Setup page:
"Use router as DHCP server" (see attached image).
I had thought that this means what it says and the Orbi can stay in router mode but not be a DHCP server.
I cannot test this because my modem is "only a modem" and if I turn off DHCP then I will have no DHCP.
I have cable Router with built in dhcp so dont therefore need the Orbi used as dhcp but as good access point.
