RobAllen
Jan 06, 2021Aspirant
RBR/RBS10 Mesh wifi
Hello all. I have an Orbi mesh wifi setup. Comprising RBR10 and 2 RBS10 satellites. My question is regarding dhcp. If I disable dhcp on the RBR10 does the mesh system then just act as wifi repeater/s...
- Jan 06, 2021
Correct.
Jan 06, 2021Guru - Experienced User
Yes. There should be a AP mode setting though under Advanced Tab/Advanced Settings for that.
RobAllen
So I need to disable router mode and select AP instead so it just emulates the existing wifi correct?
- FURRYe38Jan 06, 2021Guru - Experienced User
Correct.
- CrimpOnJan 06, 2021Guru - Experienced User
RobAllen wrote:So I need to disable router mode and select AP instead so it just emulates the existing wifi correct?
My Orbi has a check box on the Advanced Tab->Setup->LAN Setup page:
"Use router as DHCP server" (see attached image).
I had thought that this means what it says and the Orbi can stay in router mode but not be a DHCP server.
I cannot test this because my modem is "only a modem" and if I turn off DHCP then I will have no DHCP.
- RobAllenJan 06, 2021Aspirant
I have cable Router with built in dhcp so dont therefore need the Orbi used as dhcp but as good access point.
RobAllen wrote:I have cable Router with built in dhcp so dont therefore need the Orbi used as dhcp but as good access point.
The discussion has wandered from the original question, "can the Orbi DHCP server be turned off" to a different topic:
"Is it a good idea to have the Orbi as a router connected to another router?" Thousands of Orbi owners do this and experience no problems. (They just unbox the Orbi, plug it in, start using it, and are happy.)
However, this is technically a "Double NAT" condition, which can seriously impede specific network applications, such as VPN, opening port to expose servers to the internet, and some internet gaming. A Google search will turn up many explanations, such as the one from Netgear: https://kb.netgear.com/30186/What-is-Double-NAT
Putting the Orbi into Access Point (AP) mode is one solution that is often suggested. That has a side-effect of eliminating a host of Orbi features: https://kb.netgear.com/000061277/Disabled-Features-on-the-Orbi-when-set-to-AP-Mode If you want to use Armor or Circle, then the Orbi has to stay a router.
There is no "right answer", as long as you are aware of the situation.
