ck33
May 25, 2018Aspirant
RBR/RBS50 2.1.4.10 dropping internet
Hi All,
About 2 months ago I bought the RBK53 RBR50+2 RBS50 at Costco. I had installed one RBR50+RBS50 at my parents with great results. In this setup I have the RBR50 in the basment where th...
May 25, 2018Guru - Experienced User
Can you test the system with out the Sonos devices turned ON? Seen issues with these devices.
What is the distance between the router and satellite? Should start with 30feet in between and go past this.
What channels are you using? Try 1, 6 or 11 on 2.4Ghz and any unused channel on 5ghz.
Any wifi neighbors near by? If so, how many?
Disable MIMO, Daisy Chain and Fast Roaming and see how it goes.
Besure your ISP modem is up to date on FW:
ck33
Hmm, I see my SB6190 listed as a bad modem. It would be odd in my mind if issues with the modem caused some clients to loose internet and not others, but as this modem looks problematic and I have an older modem that should run as fast as my ISP specs I will swap that out first and give it a try. In the interest of speed I will also turn off daisy-chain. This may kill my performance upstairs but it is worth a test. MU-MIMO, Fast Roaming and BEAMFORMING are all off, I hadn't looked at turning them on and they seem off by default. Thanks for the pointers, I'll start here and see if I can improve things. I have a gut feeling about daisy-chain, though that not working would bite. I can try to work out a better setup, but I was counting on not pulling cable up from the basment, and placing the satilites where I need wired connections. Hence the dual satilite setup (with all the $$$)!
- FURRYe38May 25, 2018Guru - Experienced User
I would try to get the Orbi router up on the main floor if possible. Then place the satellite(s) were needed. Starting distance recommended is 30 feet in between.
You can leave beamforming enabled. This shouldn't impact performances. I have it enabled on mine.
