ck33
May 25, 2018Aspirant
RBR/RBS50 2.1.4.10 dropping internet
Hi All,
About 2 months ago I bought the RBK53 RBR50+2 RBS50 at Costco. I had installed one RBR50+RBS50 at my parents with great results. In this setup I have the RBR50 in the basment where th...
st_shaw
May 26, 2018Master
ck33 wrote:
Hi All,
About 2 months ago I bought the RBK53 RBR50+2 RBS50 at Costco. I had installed one RBR50+RBS50 at my parents with great results. In this setup I have the RBR50 in the basment where the cable and cablemodem are, one RBS50 on the 1st floor and a RBS50 on the second floor. Coverage is great and the thing is blazing fast. I have one big problem. Every few days some devices loose connectivity to the internet. A month ago I discovered turning off the 2nd floor RBS50 made the problem go away, though with slower speeds upstairs. I've since updated to 2.1.4.10 firmware and still have this problem. After a day or two some devices can't get to the internet. I power off the 2nd floor RBS and it all comes back. Power it back on and things are fine for a bit.
Can anyone give me some pointers on how to troubleshoot this? I'm pretty familiar with linux and networking (25 YEARS familiar, starting on AIX). I'd love to try something before bringing this all back and trying some other mesh wifi. Other details of my setup:
- ARRIS SB6190 cablemodem (owened by me) connected to comcast xfinity
- 5 Sonos speakers connected via a Sonos BRIDGE
- ORBI is in router mode. I do have an Edgerouter Lite I used prior to the Orbi I could press back into service and try this in AP mode.
Thanks in advance for any help I can get on this.
You must manually configure both Orbi and Sonos to use non-overlapping 2.4 GHz channels, or they can interfere. Set one system to use CH 1 and the other to use CH 11. Do not use Auto channel selection on either system.
ck33
Jun 12, 2018Aspirant
Thanks for the tips. Failures take several days so troubleshooting has been slow going. So far I have:
1. Moved satellites within 30 ft
2. Replaced cablemodem with a model not known to be problematic
3. Turned off Daisy-Chain, MU-MIMO, BEAMFORMING and Fast Roaming (the last 3 of these were already off)
Still having the issue so now I am looking at SONOS. I don't think I want to turn these off as I use them constantly. I will move them to a different channel and do some more research on them.
- st_shawJun 13, 2018Master
See my post above about Sonos, follow those instructions and make sure you wire only one Sonos device, no more. As an alternative setup, you could remove the bridge, wire NONE of your Sonos devices, and connect them via WiFi. (I use a bridge with no issues, and prefer this setup.)
You should download the new 2.1.4.16 firmware and update to that also.
If you still have trouble after that, I would put the edgerouter back into service and run Orbi in AP mode. That's how I run mine and I've never had any issues.
