Orbi101's avatar
Orbi101
RBR/RBS50 broadcasting multiple SSID
Hi! Sorry if this is a redundant question (I did check...)
I just installed the RBR50 and two RBS50's (including firmware updates, AP setup). One RBS50 is cabled to the router, the other has a wireless connection (from connected devices).
I changed SSID twice from the factory SSID (let's say SSID1 and SSID2) but now have both SSID1 and SSID2 broadcasting (rather than just SSID2).
What went wrong and how to fix this?
Any help is appreciated!
  • CrimpOn, thanks! I found that the wired satellite was not updating its SSID (no idea why but this should not happen!). I reset the satellite, ressynchonized and everything is fine now.
    Great feedback!
  • CrimpOn's avatar
    CrimpOn
    Might be useful to determine which Orbi is broadcasting which SSID.  i.e. turn off one of the satellites.  Does the wrong SSID disappear?  Turn off the other satellite and check again.  Since it is "impossible" for the Orbi to broadcast two SSID's (hah), my guess is that one of the Orbi satellites is no longer connected correctly.  OR.... the wrong SSID is coming from a different WiFi access point, not the Orbi at all.
    • Orbi101's avatar
      Orbi101
      Great feedback!
