salevine
Jun 05, 2020Aspirant
RBR/RBS50 Connection Type question
I have an RBR 50/RBS50 setup. The satellite is connected to the network via cable so I could get fastest connectionss. When I look at the control panel under "Connection Type" on the satellite - it ...
Jun 05, 2020Guru - Experienced User
Yes it should...
Is the Orbi system operating in Router or AP mode?
Is RBS directly connected to the RBR or via a switch?
What is the Mfr and model# of the ethernet switch in the configuration?
https://kb.netgear.com/000051205/What-is-Ethernet-backhaul-and-how-do-I-set-it-up-on-my-Orbi-WiFi-System
salevine
Jun 15, 2020Aspirant
So its working now. At some point, i guess I moved the main base station and the wire got plugged into the WAN port instead of one of the numbered ports. Once I moved it - it solved that problem. Now I just get the light always being pink, but that is fine.
- FURRYe38Jun 15, 2020Guru - Experienced User
How do you mean?
The WAN port on the RBR should be connected to the ISP Modem or host router.
