Jason7
Dec 23, 2020Aspirant
RBR/RBS50 FIRMWARE UPDATE general advice please
Hi RBR50 v1 here, working fine for 2 years without any issues. I am a naive user with little IT knowledge :smileyhappy: I have been reading alot of firmware update posts and the ensuing complex ...
Dec 23, 2020Guru - Experienced User
Unless NG pushes FW to your system. You can choose to update your FW to your system or not. If you get notifications on the RBRs web page about a FW udpate, this is only a FW notification. Means it's available to you IF you wanna update. You dont have too..
Some believe that if yoru system IS working fine, then you don't need to udpate. This is also recommended. However at some point NG may push a FW update to your system.
Recommended FW version to use is v16 on 50 series Orbi...
Jason7 wrote:Hi RBR50 v1 here, working fine for 2 years without any issues.
I have been reading alot of firmware update posts and the ensuing complex problems, and would greatly appreciate just some general advice for those of us who are casual users :smileyhappy:
At the moment, the app states an update is available for my unit. Orbilogin.com shows I currently have V 2.5.1.16 and V 2.5.2.4 is "available" for router and satellite..
So - for those of us naive users out here, is it possible to give some general advice?, ie:
1 - Only let the ORBI upgrade automatically?
2 - Only upgrade when the app shows an update is available, and update directly from the app?
3 - Actively check if if there is an update available at orbilogin.com/advanced/administration/firmware update, and download those updates periodically?
Many thanks,
Jason
Jason7
Thanks both for your advice.
FURRYe38 - one question please:
When you say "Unless NG pushes FW to your system" -- does that mean that NG automatically updates my units, ie, I do nothing in this case?
Many thanks,
Jason
- CrimpOnDec 23, 2020Guru - Experienced User
Jason7 wrote:When you say "Unless NG pushes FW to your system" -- does that mean that NG automatically updates my units, ie, I do nothing in
Yes. When it first came out, Orbi was like many "Internet of Things" (IoT) devices. It was supposed to "just work" without the user doing anything. There were a number of firmware updates that happened silently in the night. (As far as I am aware, the Nighthawk line of products NEVER did this. It was always up to the user to recognize that new firmware was available and decide to install it.) Alas, some of these updates caused major issues for users and there was a significant "Hue and Cry". Since then, Netgear has floundered in regard to Orbi updates. People post that their Orbi updated firmware without them doing anything to cause it. The Orbi "app" will announce new firmware when the Orbi web interface claims "no new firmware available." Orbi will announce new firmware that is not the "most recent" release. Netgear also emails customers about "security update to firmware". From my viewpoint, customers have good cause to be confused.
As things stand today, "old timers" recommend, "If it ain't broke, don't fix it. Leave it the hell alone." If the Orbi is not working correctly, then a person has to balance the odds that (a) newer firmware will be "better" against, (b) newer firmware will either 'brick' the Orbi or will cause some new problem.
Will Netgear ever "push" new firmware to Orbi without the user doing anything? NO ONE KNOWS.
- alokeprasadDec 23, 2020Mentor
As a counterpoint to "don't fix what isn't broken", a firmware that has security vulnerabilities, especially if there are exploits in the wild, is broken. Netgear lists the vulnerabilities and fixes (in some cases) on
https://www.netgear.com/about/security/
If one chooses to stay with an older version, then it is a trade-off between stability and security. But it should be an informed decision. Like I said in my earlier post, Netgear may choose expediency over robust testing when releasing such hot-fixes.
Having been so preachy, I myself have not updated to the latest version.
- vajimDec 24, 2020Master
alokeprasad wrote:As a counterpoint to "don't fix what isn't broken", a firmware that has security vulnerabilities, especially if there are exploits in the wild, is broken. Netgear lists the vulnerabilities and fixes (in some cases) on
That's a matter of opinion.
To keep things in perspective, NG used to push ALL firmware updates. You had no choice. Then users whined and cryed and wanted more choice and freedom. Just thought you'd lke to know. :smileyhappy:
- FURRYe38Dec 23, 2020Guru - Experienced User
Yes, if your Orbi appears to have a fw update applied, you should be able to continue to use the system normally. Some have posted seeing issues after NG pushes FW. Some have not. One thing to try if you notice anything, Power OFF the RBS and RBR for 30 seconds then back on. Sometimes this resolves any odd problem seen after a auto FW update.
