matiernoII
Jul 03, 2021Aspirant
RBR/S50 & RBK853 + Switch
Currently I have an RBR50 network running. I will be installing an RBK853 network at a new property that will also inherit the RBR50 hardware. Is it doable to install a switch after a cable modem,...
Jul 03, 2021Guru - Experienced User
Just 1 RBR router only.
Netgear has set up a community forum specifically for the Orbi AX product. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
Thank you.
- matiernoIIJul 03, 2021AspirantThank you FURRYe38. I did post in the AX group.
- FURRYe38Jul 03, 2021Guru - Experienced User
