Fvog30
Jun 07, 2020Follower
RBS 20 Power Light is solid amber after turning it on.
Hi
I have two RBS20 satellites that after a year of use, are not working. Both of them, when turned on shows a solid amber Power Light even when I try to Reset them. Can somebody help me with this?
1 Reply
Does pressing the reset button for 15 seconds then release then wire connect a PC to the back of the RBS and wait about 5 minutes then open a web page to 192.168.1.250 result in anything?
