Crazydriver147
Aug 31, 2020Aspirant
RBS 20 satellite
I have hard wired and connected to the RBR 40, why am I not getting the same speed at the main router ? Need help the current setup is the rbr40 is the Ap connected to the wall satellite which came i...
Crazydriver147
Also I tried changing the setting from the orbi being a router to an AP. Does this help ?
should I use a gigabit switch in my set up.
thanks,
Crazydriver147
The main router and the rbs20 satellite are about 50 ft apart. It does catch signal as I tried to connect it wirelessly and it was blinking magenta through out. When I wired the rbs20 then standing right next to it I'm getting on 90 to 95 mbps.
