DeanB1452
Oct 17, 2020Apprentice
RBS 20 status stays on Config Sync
I have a RBK53S system with an additional RBS20 satellite. One RBS50 is wired while the other is wireless for backhaul. The RBS20 is wired. I have updated the RBK53 system to firmware v.2.7.0.70. ...
- Oct 17, 2020
I had done reboots and even downgraded the RBS20 back to 2.5.1.16 before. Then I upgraded back to .38 and was having issues even with factory resets. I went ahead and held in the reset button for 15+ seconds and it came back online with a good backhaul. Once I rebooted the router, the status of the RBS20 was back to config sync. Even when I power cycled the satellite it stayed on config sync until I factory reset it again. I just did a factory reset of the whole system and everything seems to be online again. Router and RBS50 satellites (one ethernet, one wireless) are on v2.7.0.70 and the RBS20 (ethernet) is on v.2.6.1.38. Let's see if it still holds up in the morning or when I reboot the router again.
Mstrbig
Oct 17, 2020Master
Factory reset the RBS20 Satellite and resync
- DeanB1452Oct 17, 2020Apprentice
