mrm18
May 18, 2020Tutor
RBS 20 vs RBS 50
I have a RBR 50 with one RBS 50 satellite. I need to add one more satellite. The RBS 20 is less expensive than the RBS 50 extender. What are the plus / minus of one over the other? Trying to decide if...
May 18, 2020Guru - Experienced User
Only the connection between the RBS20 and RBR50 will have lower speeds.
You not see any thing near 900Mpbs over wireless, RBR50 or other wise. Only wired on Orbi AC will you need near 900Mpbs.
mrm18 wrote:
I have a RBR 50 with one RBS 50 satellite. I need to add one more satellite. The RBS 20 is less expensive than the RBS 50 extender. What are the plus / minus of one over the other? Trying to decide if it's wroth the price for the RBS 50. My internet speed is 1GIG via Cox cable. Thank you
