wash
Nov 19, 2018Aspirant
RBS 40 Firmware update failure
Just purchased an orbi AC2200 RBS40, However I'm unable to update to the most current firmware. I have tried all of the previous posted solutions with no success. Need help...any suggestions? Thanks
Nov 19, 2018Guru - Experienced User
If you updated the RBR before the RBS, you may need to downgrade the RBR long enough to upgrade the RBS, once thats is updated, then update the RBR back to latest. RBS needs to be updated before the RBR router.
