ksd823
Jan 01, 2018Aspirant
RBS-40 Non-Working Piece of Junk
Purchased a two unit RBR-50 and RBS-50 set that has worked fine. However - the RBS-40 that was purchased at the same time has never been able to connect. When it is plugged in Wi-Fi is blocked on all...
DarrenM
Jan 03, 2018Sr. NETGEAR Moderator
You can try to direct connect to it and use 192.168.1.250 and see if that prompts the login for admin/password.
DarrenM
ksd823
Jan 05, 2018Aspirant
I will give that a try - I was assuming that it would pick up an address from the existing network. Will that address be available from the wired as well as wireless side?
