BHHJR
Apr 13, 2018Tutor
RBS 50 fails speed test
My Orbi keeps saying it’s failing to run a speed test and reboot the router. I have done it several times to no avail.
st_shaw
Apr 13, 2018Master
I believe there is a problem with the Ookla server used by the Orbi app for the speed test.
If you want to run a speed test, just use a speed test app or website on your client device.
- BHHJRApr 14, 2018Tutor
Thanks. I have run the Ookla speed test which is fine. So looks like the speed test in Orbi has a problem, not my router.
- GerryJ99Apr 14, 2018Aspirant
Same here. Speed test works using Ookla app on iPhone and iPad (tested with 3 different servers), doesn’t work on Orbi iPhone/iPad app or web. Orbi doesn’t give option to change Ookla server, just says if problem persists try rebooting your router (which I did to no avail).
- FURRYe38Apr 14, 2018Guru - Experienced User
NG has been reporting saying that this is there service issue and is aware of it. Keep using the external speed test apps for now until NG fixes this.
GerryJ99 wrote:Same here. Speed test works using Ookla app on iPhone and iPad (tested with 3 different servers), doesn’t work on Orbi iPhone/iPad app or web. Orbi doesn’t give option to change Ookla server, just says if problem persists try rebooting your router (which I did to no avail).
