BHHJR
Apr 13, 2018Tutor
RBS 50 fails speed test
My Orbi keeps saying it’s failing to run a speed test and reboot the router. I have done it several times to no avail.
st_shaw
Apr 13, 2018Master
I believe there is a problem with the Ookla server used by the Orbi app for the speed test.
If you want to run a speed test, just use a speed test app or website on your client device.
BHHJR
Apr 14, 2018Tutor
Thanks. I have run the Ookla speed test which is fine. So looks like the speed test in Orbi has a problem, not my router.
