Hausdog
Aug 16, 2021Follower
RBS 50 Firmware update
I've had this Orbi WIFI for 5-6 years without a single problem. I thought that the firmware was automatically updated, but maybe not? If I do update, do I have to start at the first update or can I...
Aug 16, 2021Guru - Experienced User
you should be able to load new FW unless your on older v1 versions.
Up to you. Can update or leave it. If it works, dont' fix it!
Comment here if you do:
