JohnVL62
May 10, 2020Aspirant
RBS 50 Router connected to Giga Switch GS108
We have connected a GS 108 giga switch directly into the wired port of our Orbi router. If I hard connect my computer into the router, I can get internet access. Unfortunately, when I connect my com...
- May 12, 2020
Ah yes. That can happen. Glad it was a easy fix.
Please mark your thread as solved so others will know.
Enjoy. :smileywink:
JohnVL62 wrote:Thank you for all your useful suggestions and advise. Turns out someone had inserted a second input feed into the switch which was causing the switch not to work. Thank you again. Problem has been resolved.
JohnVL62
May 12, 2020Aspirant
May 12, 2020Guru - Experienced User
Enjoy. :smileywink:
