sandman512
Jan 14, 2021Apprentice
RBS 50 Satellite, running different firware versions.
So, currently running a RBR50 with THREE RBS satellites(all wired in). Just noticed that TWO satellites are running firmware version V2.5.2.4 and one is running V2.7.2.102. I checked for updates an...
- Jan 14, 2021
Always update RBS first, then RBS lastly.
sandman512
Will do, plan on doing it in a couple of hours(still at work). While I got you, should I do the router first or that one satellite? Thanks and be well!
Jan 14, 2021Guru - Experienced User
- sandman512Jan 14, 2021Apprentice
Updated and all good. Thanks!
- FURRYe38Jan 14, 2021Guru - Experienced User
Enjoy. :smileywink:
