Dave61
Dec 28, 2017Aspirant
RBS 50 Satellite "stuck" on firmware 2.0.0.74
I have just added a second satelllite to my home network. As delivered it was on firmware v1. Via the admin panel I did a firmware update to v2, however I notice that whilst the router and first sate...
- Dec 28, 2017
You need to unzip the file and then load the RBS50-V2.1.1.16.img file.
mahughesnh
Dec 28, 2017Guide
When my router updated to the latest firmware, the satelite did not update. I did the update manually and it was fine. Not sure why it didn't update automatically, it always has with past updates. But it was not a big deal to do it manually. Just follow the instructions in the advanced screen of the router interface and it took about 5 minutes to complete and link up.
- Dave61Dec 28, 2017Aspirant
Thanks, manual update was a good idea, but I get an error: "This firmware file is incorrect! Please get the firmware file again and make sure it is the correct firmware for this product."
I downloaded the file and tried again, with the same result.
- DarrenMDec 28, 2017Sr. NETGEAR Moderator
Try to power cycle that satellite unit then try the update again.
DarrenM
Thanks, just tried that but still same error.
- mahughesnhDec 28, 2017Guide
Make sure you download the firmware for the RBS50, not the RBR50. Easy mistake to make.
Thanks, double checked. Unless Netgear are mislabelling files it is definitely the RBS version.
