indypharmd
Jul 20, 2018Aspirant
rbs 50 satellite will not sync with rbr50 router
I have an Orbi Wi Fi mesh rbr50/rbs50 system that won't connect a satellite unit.
I've factory reset multiple times and downgraded the router server to a 1.10.x version (was on latest). I canno...
Jul 27, 2018Guru - Experienced User
Did you connect the satellite to the router or did you connect your PC to the satellite? I believe you can connect your PC to the satellite...
- indypharmdJul 27, 2018Aspirant
yes, directly plugged into ethernet point on the mac and the satellite. Ran ifconfig in terminal and no listing for eth0...
