indypharmd
Jul 20, 2018Aspirant
rbs 50 satellite will not sync with rbr50 router
I have an Orbi Wi Fi mesh rbr50/rbs50 system that won't connect a satellite unit.
I've factory reset multiple times and downgraded the router server to a 1.10.x version (was on latest). I canno...
Jul 27, 2018Guru - Experienced User
Did you connect the satellite to the router or did you connect your PC to the satellite? I believe you can connect your PC to the satellite...
indypharmd
Jul 27, 2018Aspirant
yes, directly plugged into ethernet point on the mac and the satellite. Ran ifconfig in terminal and no listing for eth0...
