yankees177
Nov 29, 2020Aspirant
RBS 50 shows blue then goes magenta
I am having a heck of a time syncing an RBS50 to my RBR50. I got a unit second hand that was working and it will not set up. I have tried factory resetting multiple times, adding through the app and m...
yankees177
Hey so just tried. I can connect via WiFi to the satellite but when I go it it says https://192.168.1.250 network unreachable and it doesn't give itself an IP address.
I tried an ethernet cord which ays unidentified network and I try to connect to that and it says network unreachable as well.
What am I doing wrong?
CrimpOn
Nov 29, 2020Guru - Experienced User
What WiFi name allows you to connect to the RBS50 after it has been factory reset?
When connected to the satellite with an ethernet cable, can you open a web browser to http://192.168.1.250?
