Andrewh37
Aug 08, 2021Aspirant
RBS 750 Green Light after Sync
I have an RBR750 Orbi router with four RBS 750 satellites. My system worked well for a number of months but recently one of the Satelittes loses connection, flashes white and then shows a green light. The connection speed is also slow. When I reset and re-synch the satellite it flashes white and goes green, not blue, amber or magenta. Any ideas on the what this means?
Thanks Andrew
Netgear has set up a community forum specifically for the Orbi AX product. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-axThank you.
- Andrewh37AspirantThanks will do
