Orbirbr53user
Oct 19, 2023Aspirant
RBS on a permanent magenta
My RBS20 has started to always go in 'magenta' mode. I have an RBR50 with 2 RBS50 satellites and it was not enough even though I do not have that big of a 2 storey house, the very usual English semi-...
Oct 24, 2023Guru - Experienced User
Is this happening with the RBS in same room with the RBR?
Orbirbr53user
Oct 24, 2023Aspirant
Yes, both in the same room and in another.
- FURRYe38Oct 24, 2023Guru - Experienced User
What FW version is loaded on the system?
Has the RBS and RBR been updated at all?- Orbirbr53userOct 24, 2023AspirantI have been keeping them up to date, the last time I checked (when the RBS20 was also briefly available) they were all on 2.7.4.24.
Sounds like a factory reset on the RBS and RBR is needed and setup from scratch using a wired PC and web browser.
A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router
https://kb.netgear.com/25722/How-do-I-reserve-an-IP-address-on-my-NETGEAR-router
I would power OFF the ISP modem for 1 minute. Factory reset the router and power it off. Power ON the ISP modem and let it sync. Then power ON the router and walk thru the setup wizard again using a wired PC and a web browser.
Press the back reset button for 15 seconds then release.
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
https://kb.netgear.com/000062081/How-do-I-erase-the-configuration-settings-on-my-Orbi-WiFi-SystemAfter you reset the RBR and RBS, do this with RBS in same room as the RBR. What for the RBS to blink WHITE and maybe turn BLUE as they should normally turn BLUE and connect to the RBRs default SSID name. Then walk thru the setup wizard using a PC and web browser at 192.168.1.1 and the setup wizard should find all RBS.
