JJAlf's avatar
JJAlf
Follower
Jun 02, 2020
RBS10 only shows solid green light and will not sync
My Orbi RBS 10 only shows a solid green light and never syncs with my orbi RBR10 router. I've tried a number of times to sync it but the light never changes from solid green. Any help would be appreciated. Thanks!
  • CrimpOn's avatar
    CrimpOn
    Oh, dear.  The RBS10 User Manual mentions on page 12 that the LED will remain solid BLUE when the satellite is connected and working normally.  "Green" does not appear to be one of the possibilities.
    http://www.downloads.netgear.com/files/GDC/RBK12/RBK12_13_14_UM_EN.pdf
    • jalowe's avatar
      jalowe
      I have the same issue. Manual may not give give green LED as an option....but my RBS10 is showing it none the less.  It won't reset when reset button is pushed, won't sync when SYNC is pushed. LED remains steady green through all of these actions.
