Spence43
Feb 27, 2024Tutor
RBS10 Solid green then flash white
You are incorrect RBS10 does in fact have a green led. I have one and I have seen it , many times
michaelkenward
Feb 27, 2024Guru - Experienced User
That's not what the manual says.
Maybe one person's blue is another's green.
Amber and red often get confused with one another.
But let's not argue about colours, anything more to add to the suggestions that might help?
I would also suggest checking that the units all have the latest firmware.
Spence43
Feb 27, 2024Tutor
Not arguing , just giving proper info on this model because I have one. I have seen green , blue, amber , white and red.
- michaelkenwardFeb 28, 2024Guru - Experienced User
When do you see green? What is happening?
Netgear is famous for not update its manuals. So maybe your experience would be useful.
- Spence43Mar 03, 2024Tutor
On initial power up it's solid green for a moment.
