sepatterson86
Jul 22, 2021Aspirant
RBS20 - Blinking white light and red blinking power button - won't update or reset
My Orbi RBS20 Satellite has been blinking with a white light on the top and the power button blinks red. My other satellites have the most current firmware, but this one won't update. I've tried ev...
Jul 22, 2021Guru - Experienced User
Try swapping power adapters with on of the other RBS adapters to see if this changes anything.
Press the reset button for 15 seconds then release. Do anything different?
If not, RBS is probably faulty and needs to be replaced.
- sepatterson86Jul 22, 2021Aspirant
Unfortunately, that didn't make a difference. Thank you for the suggestion, though!
