nsquid
Oct 28, 2020Aspirant
RBS20 - disconnects when connecting ethernet backhaul
So last week i pulled out my linksys velop mesh after finding that, for some reason that neither myself or linksys support could determine, i was only getting about 30% of my ISP speed even on wired ...
- Oct 28, 2020
Is Daisy Chain enabled? Disable it to see.
Is the RBS directly connected to the RBR or is there a switch in between?
If so, What is the Mfr and model# of the ethernet switch in the configuration?
https://kb.netgear.com/000051205/What-is-Ethernet-backhaul-and-how-do-I-set-it-up-on-my-Orbi-WiFi-System
Oct 28, 2020Guru - Experienced User
- nsquidOct 29, 2020Aspirant
Good call - topology is modem>router>netgear gs110tp 8 port gig switch.
This switch connects to an 8 port patch in my garage which connects to the ports in the rooms, where the satellites were connecting - disabled daisy chain, and we're good to go!
Also found the fast roaming, beam forming, and MIMO settings on that page as well.
Thanks!
- FURRYe38Oct 29, 2020Guru - Experienced User
Enjoy, :smileywink:
