jkeun
Jun 28, 2021Aspirant
RBS20 alternative
Since a year I use the RBK23 system, which has the router and two satellites. I now want to add another satellite (RBS20) to it, but can't find this anywhere (at a decent price). This also goes for R...
Jun 29, 2021Guru - Experienced User
RBW30, RBS40v(oice) or EX7500/7700 or 8000 extenders.
- jkeunJul 06, 2021Aspirant
All Wifi5 sattelites seem no longer available (at least new). If I add a wired access point (f.i. WAX214) on the third floor, does this also works seemless?
Or do I then have to switch between SSID's?
- FURRYe38Jul 06, 2021Guru - Experienced User
If you set the WAX214 on same SSID and PW and used different channels from what the Orbi uses, then devices should connect fine on there own.
