vordesigns
Aug 09, 2021Aspirant
RBS20 Connected to RBR20 (AP Mode) stops transmitting client traffic
Shotgun house, Orbi RBR20 in the middle, 1 RBS20 about 25' away in both directions. They have been working reasonably fine. Now, 1 of the satellites shows 5G backhaul connection but, intermittently...
michaelkenward
Aug 10, 2021Guru - Experienced User
vordesigns wrote:
.... sometimes if I run Windows 10 Troubleshoot, it reports that the gateway couldn't be found so it resets the WiFi or wireless depending on the system and reports that the gateway was missing.
Makes me ask you about the modem, if there is one, in front of your router.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Orbi - NETGEAR Communities
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
