teeg126
Sep 10, 2018Initiate
RBS20 Ethernet Wired Backhaul
Can you hardwire RBS20 for wired backhaul?
Sep 10, 2018Guru - Experienced User
teeg126
My RBS20 don't have the same ports as that. Basically looks like only Ethernet OUT, not IN
- FURRYe38Sep 10, 2018Guru - Experienced User
You should have two ethernet ports on the RBS20 as see here on page 16:
http://www.downloads.netgear.com/files/GDC/RBK50/Orbi_UM_EN.pdf
These can be connected to a switch or the back of the Orbi router directly. These are bi directional ports.
