teeg126
Sep 10, 2018Initiate
RBS20 Ethernet Wired Backhaul
Can you hardwire RBS20 for wired backhaul?
teeg126
My RBS20 don't have the same ports as that. Basically looks like only Ethernet OUT, not IN
Sep 10, 2018Guru - Experienced User
You should have two ethernet ports on the RBS20 as see here on page 16:
http://www.downloads.netgear.com/files/GDC/RBK50/Orbi_UM_EN.pdf
These can be connected to a switch or the back of the Orbi router directly. These are bi directional ports.
