KitchSB
Jan 29, 2021Aspirant
RBS20 firmware version
Currenltly using 2.5.1.16 and check for upgrade on orbilogin says none available. But Netgear website says current download version is 2.6.1.38.
Should I manually upgrade
Why does orbilogin not suggest new version?
NG hasn't put the newer up on there auto update servers is all. You can update as well. Seen some users post having problems with recent versions of FW. You can manually download and manually update your system if you want to.
https://kb.netgear.com/31573/How-do-I-manually-upgrade-firmware-on-my-Orbi-router-using-orbilogin-com
https://kb.netgear.com/000037217/How-do-I-check-and-manually-upgrade-the-firmware-on-my-Orbi-satelliteIf you choose to update, update the RBS first then RBR lastly. I would perform a reset on the system and setup from scratch after loading FW if you notice problems after the update is applied.
- KitchSBAspirant
If some users having trouble with new FW, should I wait until formally release on orbilogin?
