tgarvey
Mar 18, 2019Tutor
RBS20 FW update
My package of an RBR40 and three RBS20s would not automatically detect and run the 2.3.0.28 FW updates when I logged in via my browser. I downloaded the two firmware files and first upgraded the RBR...
Mar 18, 2019Guru - Experienced User
There should be a .img file after unpacking the .zip file. This is the FW file.
Check your zipper program to make sure it's unpacking the .zip file correctly.
tgarvey
Mar 18, 2019Tutor
Yep, I've been using the img file, and I've downloaded & extracted it about five times now, using the same zip app that suucessfully extracted the RBR40 file. I'll try it again in a day or two if the auto-update still hasn't gotten the holdout done.
BTW, do you know if you still need to leave Daisy Chain on?
Thanks for your suggestions.
- FURRYe38Mar 18, 2019Guru - Experienced User
Yes thats the correct file for the RBS.
Depending upon if you have the satellites connected via ethernet or wirelessly connected and placed in a linerar line out from the router or in a star formation with the router, would dictate if Daisy chain is needed. Wired ethernet or Star formation, Disable DS.
