tgarvey
Mar 18, 2019Tutor
RBS20 FW update
My package of an RBR40 and three RBS20s would not automatically detect and run the 2.3.0.28 FW updates when I logged in via my browser. I downloaded the two firmware files and first upgraded the RBR...
tgarvey
Mar 18, 2019Tutor
Yep, I've been using the img file, and I've downloaded & extracted it about five times now, using the same zip app that suucessfully extracted the RBR40 file. I'll try it again in a day or two if the auto-update still hasn't gotten the holdout done.
BTW, do you know if you still need to leave Daisy Chain on?
Thanks for your suggestions.
Mar 18, 2019Guru - Experienced User
Yes thats the correct file for the RBS.
Depending upon if you have the satellites connected via ethernet or wirelessly connected and placed in a linerar line out from the router or in a star formation with the router, would dictate if Daisy chain is needed. Wired ethernet or Star formation, Disable DS.
