tgarvey
Mar 18, 2019Tutor
RBS20 FW update
My package of an RBR40 and three RBS20s would not automatically detect and run the 2.3.0.28 FW updates when I logged in via my browser. I downloaded the two firmware files and first upgraded the RBR...
Mar 19, 2019Guru - Experienced User
Good to hear. Let us know how it goes.
If you need to, try a factory reset and setup from scratch.
Good Luck.
tgarvey wrote:
My package of an RBR40 and three RBS20s would not automatically detect and run the 2.3.0.28 FW updates when I logged in via my browser. I downloaded the two firmware files and first upgraded the RBR40 successfully. (Yes, I know now you're supposed to do the satellites first.) The RBS20 update has failed several times, with a message saying I'm using the incorrect file. I've re-downloaded it several times and get the same result. Any suggestions?
