Kneafseym
Mar 30, 2021Tutor
RBS20 have to Satellites and trying to add two more
I have been happily using an ORBI RBS 20 with 2 Sats for a long time. I just bought 2 more (used) and I can connect to them via wifi, but I cannot get them to sync to the existing. I am using the...
CrimpOn
Mar 30, 2021Guru - Experienced User
Kneafseym wrote:I have been happily using an ORBI RBS 20 with 2 Sats for a long time. I just bought 2 more (used) and I can connect to them via wifi, but I cannot get them to sync to the existing. I am using the App and have tried many times, the steps seem very straight forward.
I seem to remember reading posts that the Orbi "Add a satellite" function is limited to displaying three satellites at one time. People report using a "work around" to have more than three satellites:
- Add satellites using the Orbi web interface, not the Orbi "app".
- Once there are three satellites, adding more requires a "trick"
- Power off one of the existing satellites.
- Wait until the Orbi Attached Devices page shows the satellite as "Disconnected" and ignore the option to delete it.
- Use the "Add a satellite" procedure to sync another satellite.
- Power that existing satellite back on.
What appears to be going on is that the web page for Adding a satellite can only handle three satellites, whereas the Orbi router can be connected to as many as six. (I have not seen reports of more than six. Who knows how many would work?)
