chuee
Sep 29, 2022Aspirant
Rbs20 is sattelite ethernet is connected but no internet connection
I have an orbi RSB20 satellite that I have for ethernet for my iMac. it has been working fine until around last week when it decided to just not work overnight. I have been able to use the main wifi ...
chuee
I just tried that and I am still getting the connection is not private regardless what i search up
CrimpOn
Sep 29, 2022Guru - Experienced User
The Chrome browser does this. What happens when you use Safari?
- chueeSep 29, 2022Aspirant
I just got "the Safari cannot open page"
- CrimpOnSep 29, 2022Guru - Experienced User
My web browsers usually have a link (often in very small type) for "advanced options" or "more details".
Could it be that these browsers are attempting to open their default Home Page web sites?
What happens when you enter a different web site, such as Google.com?
The same thing happenes. its basically as if I was on the circle parental controls and all the websites were restricted. for example you can go to youtube but once your on the site it says no internet connection
