oliubushyn
Feb 19, 2021Tutor
RBS20 only 40Mbps
Hello, community, I am running into a strange issue with RBS20 Sattelite device. I have CBR40 router connected to Xfinity, and I have a strong 400Mbps. Also, I have RBS20 connected to the router by...
oliubushyn
Feb 19, 2021Tutor
I saw it. Did everihitng and no luck.
Feb 20, 2021Guru - Experienced User
Something to contact NG support about. This problem seems to need there attention and is something we can't fix or resolve here in the forums.
- oliubushynFeb 20, 2021Tutor
Thanks for the response. Can you please help me to find out best way to contact support. Seems Netgear has no way to do it without premium. I am surprised :)
- FURRYe38Feb 21, 2021Guru - Experienced User
Send a forum moderator a private message. Just select the name I added in my prior post.
- oliubushynFeb 22, 2021Tutor
Thanks
